AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
sensor symbols
1 REPLY 1
JohnnyTheAnt
6342 Views, 1 Reply
sensor symbols
guys,
In our company we design control panels ranging from lv distribution systems to full blow bems systems.
At the moment i'm designing a full blown bems control system using IEC library as my default (IEC2), are there any iec symbols for sensors (say NTC 10K3A1 or NTC20kohm)?
I also have the same problem for modulating 3 port heating valves.
Kind regards,
Johnny Battiste
1 REPLY 1
Here are a couple of Pt100 symbols I use; one vertical and one horizontal. These are sized for the IEC2 library. The default RATING1 attribute value is Pt100 but this can be changed to fit your needs.
The main difference in this symbol and the built-in Variable Resistor 2 that ships with AcadE is the B for the default TAG1 attribute value, the removal of the arrow, and the addition of the qualifying symbol for RTD.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
”Boost
