How can I search the entire project (129 pages) for a teriminal. My panel editor is showing a terminal in it that must have been placed by mistake but I don't know how to search the entire project to find the teminal and delete it.
There is a search utility available called SURF. Look for an icon of a stick figure riding a surfboard.
Click this icon, them hit enter and type the terminal strip ID in to the item tag box or select the correct terminal strip ID from a visible terminal.
Now look through the list for the terminal number you need.
Select the terminal then click on "Go To"
Acad will now moving you to the correct dwg before zooming in on the one you need. Note that it will QSAVE the dwg you are on if it needs to move to a different dwg.
Regards Brad
Brad Coleman, Electrical Draftsman
You could also place the errant terminal on your panel and then surf from there.
Thank you for your help it was greatly appreicated. The key was I had not assigned the strip ID which makes searching for it much easier.
Again, thank you.
