AutoCAD Electrical Forum
scale components after insert
4 REPLIES 4
Dan_Margulius
6062 Views, 4 Replies
How can I scale up only the electrical blocks in the scheme.
They came out a little bit small. i work with Eletrical 2013
Dan
4 REPLIES 4
in reply to: Dan_Margulius
Sware/Update block - Option B - Update a block - Choose scale. Is this you are looking for?
Dan_Margulius
Thank you.
Dan
I want to make a small comment on your answer. Where the command is, or what it actually is would be helpful for those of us new to Electrical. I had to use the help command to find the following:
Ribbon:  Schematic tab  Edit Components panel  Swap/Update Block.
Toolbar: Insert Component
Menu:  Components  Component Miscellaneous  Swap/Update Block
Command entry:  AESWAPBLOCK
Just an FYI
Icemanau
Try swapping your block library. From the looks of the screen capture, you are using a smaller library than required for the sheet size.
For example, you might be using IEC2 when for the sheet size, you may need to be using IEC4. The only differrence between the two libraries is the scale of the inserted blocks.
To swap a library, go to the Swap/Update block tool and in section 'B' choose the second option. Choose the appropriate library and let the tool run.
Regards Brad
Brad Coleman, Electrical Draftsman
”Boost
