Can we rename Drawing Name using Vb.net in autocad electrical?
I used the code Rename(oldpath,Newpath)
But its not work,Please Send Code If anybody know..
File name is part of the project file (text file with .wdp extension).
If file name is changed, it must be changed in the project file too, so that ACADE Project Manager can find that file.
Vladimir
ACADE has AutoLISP API.
You use c:wd_proj_wdp_data function to read wdp file, and c:wd_proj_wdp_write to write to wdp file.
There are samples how to use API with Object ARX and Visual Basic.
Hope this helps.
i renamed drawing and i also changed WDP file.
i can see in the folder,but in autocad i cant get that..
It will be renamed in folderwise and WDP file also,
but it doesnot show in autocad electrical..
I renamed drawing in folder and WDP file..It renamed well...
But i cant see in autocad electrical at that time,Once i restart autocad electrical it will renamed correctly..
Autocad electrical is not refresh,if i click refresh icon it will not refresh,,
But if i open another autocad electrical,it renamed correctly.
Hi
Why are you trying to do what you are asking? It is all so simple using the ribbon. This might be an excuse as I do not understand the programme you are writing.
To change the drawing names the files must be in the project with the project active. Close the drawing within the project and then rename the drawing. Use the rename button within the project. This does all the house work for you.
I will follow this thread with interest.
Cheers jq
Actually, i want to rename drawing name using vb.net?
So,I renamed Drawing name in WDP file...
when i renamed drawing name in wdp file using vb.net code, it will changed drawing name correctly in Wdp file and folder also..
But i cant see that changes in AutoCAD Electrical Window. Once i restart AutoCAD Electrical, i can see that changes.
ACADE is not aware of changes done only using vb.net.
Using API functions or RENAME command, project update is invoked.
Project update is also invoked on ACADE restart and that is why changes are seen.
API function for opening project is c:wd_makeproj_current.
By opening some other project, active project is closed.
Again, this is LISP function.
I'm not sure, but in Visual Basic something like
ThisDrawing.SendCommand ("(c:wd_makeproj_current wdpfnam)") should be used,
where wdpfnam is full path of project ".wdp" file name (this project does not have to be displayed in the list i.e. does not have to be "open").
Hi Kani
I said I would follow this thread as I am interested. I looked up what the code for what you are doing amd I ask: WHY?
ACE is data base driven. It will let you edit drawings using ACAD commands BUT it will "break" the data base.
This is from accidental experience and more learned contributers to this forum.
I have written FORTRAN, assembler for various chips and computers, HTML.
I am sure you will achieve what you are aiming toi achieve but will ACE work? IMHO a big NO. I am willing to listen and learn.
If you need non ACE users to see drawings then get a suitable free viewer.
Cheers with interest John Q
It works well..
I want to close a project,instead of closing manually.
To close a project, right-click the project name and select Close.
I want to close project using command line function..can?
