First, I have Created one Block using vb.net.
Second,I have Exploded That Block and Add some more attributes to that Block using vb.net..
Now I want redefine the block,that means exploded objects are again converted to block..
How should i do?using vba I have to redefine that block..
Don't know much about VBA. But if you want to turn your exploded objects back into a block use wblock on the command line. Follow the instructions. Save to a dwg file. If you need to make any adjustments - open it and edit it.
