AutoCAD Electrical General
Active Contributor
jdenny
Message 1 of 3 (205 Views)
"GAUGE" Attribute Name
205 Views, 2 Replies
12-03-2012 02:26 PM
In the "conductor list" option for cable, there are spaces for "color/ID" and "gauge". I would like to create a cable marker symbol (HW01-xx) that will display the "color/ID" as well as the "gauge" when inserting a cable. I have found the the "color/ID" attribute is actually called "Rating1" for the HW01xx symbol, but can not figure out what the "gauge" attribute is called. Does anyone know the attribute name for "gauge"? Thanks and please see attachment.
Jeff Denny
Sr. Engineering Manager
Harris Corporation
Melbourne, Florida
Valued Contributor
lionSG
Message 2 of 3 (176 Views)
Re: "GAUGE" Attribute Name
12-05-2012 10:50 PM in reply to: jdenny
Don't know if this is what you want to show regarding the gauge.
Goto the Schematic tab > Insert Wires panel> Wire Number Leader drop-down > Wire Color/Gauge Labels.
You can edit the wires gauge text and insert next to the cable markers.
As for the Gauge attribute, maybe you need to add new attribute for it, not very sure on this.
Anyone?
rhesusminus
Message 3 of 3 (166 Views)
12-06-2012 04:20 AM in reply to: jdenny
This information is not transferred to the symbol as far as I can see.
Do you need this information for every cable part?
If it's enough with a "4x2,5mm2" on the cable parent, you could always put "DESC1=4x2.5mm2" in the TEXTVALUE field for your cable. Also, make sure the DESC1 attribute is available.
Or, you could create your own cable parent, and add a GAUGE-attribute to it, and use "GAUGE=4x2.5mm2" in the TEXTVALUE field.
THL
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
