You wires are closely spaced together so that wire wire numbers are
automatically jumping up or down on "leaders". Try this... run the "Delete
Wire Numbers" command and window the whole drawing to remove all of the wire
numbers. Now go to the schematic "Drawing Configuration" dialog and select
"Never" for wire number "Leaders" (in bottom right-hand corner of this
configuration dialog). Rerun the Auto Wire Numbers command. Now the wire
numbers will not try to attach to leaders and your drawing will look a
little better.
wrote in message news:4909770@discussion.autodesk.com...
Please see the attached AutoCADE 2005 drawing.
The wire nos. are getting placed at wrong places, other than wires.(for e.g
wire no.01,14,15). Please help in thhis matter.
