Hi guys, same question but im looking for a potentionmetter knob with % graduation for a front end panel? Still looking for this didint find anything in the actual library (Auto CAD electrical 2017)
Hi there,
You can try these,
Please mark as a solution if this works for you, kudos are always welcome.
Hi there Paul,
Draw you wire first, select the pot, drop it on top of the wire, ACE will determine the orientation of the wire and insert the symbol as either the horizontal version or the vertical version based on the wire orientation.
Thank you
