AutoCAD Electrical Forum
potentiometer symbol?
8 REPLIES 8
Message 1 of 9
pwk
4526 Views, 8 Replies
I am using ACE 2006. I am using symbol library jic125. I was looking for a built-in symbol for a potentiometer and couldn't find one. Can anyone tell me if one exists?
Paul
8 REPLIES 8
Message 2 of 9
pmccutcheon
in reply to: pwk
Using the Icon menu, look under MISC, then TRONIC. There is a VAR RES symbol, which I guess is actually in ANSI format.
We have a symbol HPT1_L_U in our library, but I suspect we made this one up ourselves. If I ever find my memory stick I can post it....
Disclaimer: our library is based on VIA17, so perhaps there are newer items out there.
Message 3 of 9
pwk
in reply to: pwk
Thanks for the help. Those look like what I want...except, I'd like them to be oriented vertically, with the tap coming from the side. Do you know if there is an easy way to do this? Do I have to create a new symbol?
Thanks again,
Paul
Message 4 of 9
in reply to: pwk
Most AcadE schematic symbols have a "vertical" version of the symbol
included in the library folder. The difference is the first character of the
block name, "H" for horizontal and "V" for vertical.
wrote in message news:4942823@discussion.autodesk.com...
Thanks again,
Paul
Message 5 of 9
pmccutcheon
in reply to: pwk
here's one symbol, I think we made it
Message 6 of 9
in reply to: pmccutcheon
Hi guys, same question but im looking for a potentionmetter knob with % graduation for a front end panel? Still looking for this didint find anything in the actual library (Auto CAD electrical 2017)
Message 7 of 9
TRLitsey
Hi there,
You can try these,
Please mark as a solution if this works for you, kudos are always welcome.
Message 8 of 9
in reply to: TRLitsey
That's perfect!! Thank you
Message 9 of 9
TRLitsey
in reply to: pwk
Hi there Paul,
Draw you wire first, select the pot, drop it on top of the wire, ACE will determine the orientation of the wire and insert the symbol as either the horizontal version or the vertical version based on the wire orientation.
Thank you
”Boost
