I'm trying to modify the plotstamp User Fields from the command prompt (not the dialog box version of the command)
I type this at the command prompt
Command: -PLOTSTAMP
Enter an option [On/OFF/Fields/User Fields/Log file/LOCation/Text Properties/UNits] : U
Enter user field 1 <>:Job #WXYZ
Enter user field 2 <>:
Command:
Howevere the values for user field are not saved ? They are blank or unchanged
The dialogue box version of the command works fine but I want to use the command prompt version of the command so it can be used with some automatic scripts
