I am running autocad electrical 2010 and am needing plc cards allen bradley 1769-of4 and allen bradley 1769sc-if8u and they are not in my plc database can I get these somewhere ?
Solved by david_brude. Go to Solution.
I manually register my databaseand. there was no library in the series of Siemens S7-1200.
I have those AB modules in my database because I or another coworker added them to the library. I could export the tables from my plc mdb file but you would have to be familiar with MS Access and have it installed on your computer in order to import. The other problem with doing it this way is, we use a customized PLC style that may not work with your symbols.
At some point you may need another module that no one has, in which case you'll have to add it yourself. I'd like to encourage you to get familiar with adding modules. AutoDesk has a wiki website that has good help for adding to your PLC database. http://wikihelp.autodesk.com/AutoCAD_Electrical/enu/2012/Help/0643-PLC643/0646-Overview646
Probably the best way is, from the PLC editor, copy a module that is close and then modify it. That way you are not starting with a blank page and wondering what goes where.
Best Regards,
David Brude
