Acadefan,
I ran a test here and I am not seeing the same results but I am just using
one of the supplied PLC block. Could you post the PLC block that you are
using, or even better, post a drawing that I could add to a project and run
a report on to see the issue you are having.
Steve
wrote in message news:4850127@discussion.autodesk.com...
Does anyone else have this problem?
