would like to know the use of Mount and Group edit boxes( at the bottom right corner) in the panel layout component insert/edit dialog box
The help files aren't covering this any good, but there is some onformation about them in http://images.autodesk.com/adsk/files/ACAD_Elec_2012_UserGuide.pdf
As far as I understand, these are just used for custom information about components, so that you can easily "group" them, and sort on them in the report generator.
