Maybe I am not understanding the issue here, so this reponse may be bogus...
but on the same dialog where you changed the icon menu name over to your new
menu name (Project dialog > Symbol Libraries subdialog), there is a symbol
library path edit box. Make sure that your new library path is listed in
this series of semi-colon delimited paths instead of the default "jic1" or
"jic125" path.
"cotch" wrote in message
news:31310702.1095092369036.JavaMail.jive@jiveforum1.autodesk.com...
> I could sure use some help on this issue!!!
> I have set up an additional component insert menu called my_menu.dat to
compliment the provided wd_menu.dat. I have the ability to swap from one to
the other. I have also copied one of the original jic libraries and renamed
it. I have changed the schematic Icon menu, pointer, located under the
project pulldown, to my_menu.dat. My problem is when I update a dwg in the
new library using wblock, both menu's seem to point to the same dwg file.
Is there a step I am missing?Do I need to edit the WD.env file? If so, what
lines should I add and where?
