The default path to the language database is: C:\Documents and Settings\Douglas McAlexander\Application Data\Autodesk\AutoCAD Electrical 2006\R16.2\enu\Support\AeData\Catalogs
As for editing, you can edit with MS Access. Open the database and click the table named MATRIX. Or you can edit via the language database editor under the Project Management flyout. The icon is a globe with a pencil tip.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
