AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
i/o via spreadsheet problem or bug
1 REPLY 1
147 Views, 1 Reply
The program seems to be missing the ability to do sheet # and line # without hex block. For example I want the sheet num to be 20 and line num to start with 01. When I running program the line num goes in just fine but sheet num does not go in at all. There is a pop up that comes up when run this spreadsheet to i/o drawing does not give you the choice for sheet num / line num unlike the project configuration and drawing config/defaults which are both set for %S%N.
1 REPLY 1
You need to enter the starting sheet number when running the Spread sheet i/o program.
”Boost
