AutoCAD Electrical General
circuit1
Message 1 of 6 (111 Views)
help please, terminal strip editor
111 Views, 5 Replies
01-20-2012 03:22 AM
 I am using terminal strip editor and when viewing my terminal strip in layout preview it shows the terminals linked vertically, ie. bottom of terminal 1 connected to top of terminal 2 and so on rather than side by side. Could anyone tell me how to change this please?
thank you
Adrian.
rhesusminus
Message 2 of 6 (108 Views)
Re: help please, terminal strip editor
01-20-2012 05:03 AM in reply to: circuit1
I guess these are your custom terminals?
Just rotate the graphics in your terminal symbol. It should be standing vertical.
THL
THL
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
circuit1
Message 3 of 6 (103 Views)
01-20-2012 05:21 AM in reply to: rhesusminus
Hi THL,
The terminal is a custom symbol and is standing vertically, the problem is not with the orientation of the terminal in the terminal strip but how it connects the terminals together. it connects them vertically together so terminal 1 is at the top and terminal xx is at the bottom vertically rather than connecting horizontally.
Thanks.
rhesusminus
Message 4 of 6 (99 Views)
01-20-2012 07:01 AM in reply to: circuit1
My bad.
Just checked. The graphics of the block should be lying HORIZONTALLY :smileyhappy:
If you've still got trouble, could you post the terminal symbol here?
THL
THL
circuit1
Message 5 of 6 (81 Views)
01-21-2012 05:21 AM in reply to: circuit1
Works like a treat.
Tahnk you so much.
Message 6 of 6 (78 Views)
01-21-2012 05:50 AM in reply to: circuit1
ACE expects to insert the terminals as a column first. If youu need to insert it horizontally, there is an option available to change the orientation during insert.
Bob Hanrahan
Ace User since 1998
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
