AutoCAD Electrical General
Active Contributor
kani_mca
Message 1 of 2 (300 Views)
export \Import drawing properties as spread sheet
300 Views, 1 Replies
02-19-2013 12:16 AM
Export Drawing properties to spread sheet in vb.net...
And Import Drawing Properties from Spreadsheet in vb.net..
How?
rhesusminus
Message 2 of 2 (235 Views)
Re: export \Import drawing properties as spread sheet
02-26-2013 10:58 PM in reply to: kani_mca
There is no API for this (as far as I can find), and the AEEXPORT2SS command doesn't support scripting.
So, the only way to do this via VB.NET, is to manually read the WDP-file/MDB-file, and to read the WD_M-block int the DWG's.
Find what you need, and write the changes back to the same place.
THL
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
