AutoCAD Electrical General
Active Member
Message 1 of 15 (339 Views)
error:no function definition: ACE_GETACTIVEPROJECT
339 Views, 14 Replies
01-17-2013 12:00 PM
I recently installed AutoCAD Electrical 2012 on my Computer, and everytime I try to insert a wire or any other component the following message pops up on the command line:
error: no function definition: ACE_GETACTIVEPROJECT
any ideas on how to resolve this issue?
Valued Contributor
Message 2 of 15 (331 Views)
Re: error:no function definition: ACE_GETACTIVEPROJECT
01-17-2013 06:27 PM in reply to: micruiz
Did you check your support file search path is correct in the Options, File tab?
Try to use the deafult button to reset the path if not.
Thanks.
Active Member
Message 3 of 15 (326 Views)
01-17-2013 08:09 PM in reply to: lionSG
I looked at the Support File Path, and this is what I got:
C:\program files\autodesk\acade 2012\acade
C:\users\public\documents\autodesk\acade 2012\support\
C:\Users\ironmangko\appdata\roaming\autodesk\autocad electrical 2012\r18.2\enu\support
C:\program files\autodesk\acade 2012\support
C:\program files\autodesk\acade 2012\fonts
C:\program files\autodesk\acade 2012\help
C:\program files\autodesk\acade 2012\express
C:\program files\autodesk\acade 2012\support\color
C:\Users\ironmangko\documents\acade 2012\
C:\Users\Public\Documents\Autodesk\Acade 2012\Libs
Valued Contributor
Message 4 of 15 (321 Views)
01-17-2013 08:59 PM in reply to: micruiz
The search paths look ok.
Try the project settings tab, check that the Schematic Icon Menu File is pointed correctly to the library that you use
For IEC, ACE_IEC_MENU.DAT.
Thanks.
Active Member
Message 5 of 15 (314 Views)
01-17-2013 09:40 PM in reply to: lionSG
I tried that, but it kept reverting back to this file:
ace_jic_menu.dat
Valued Contributor
Message 6 of 15 (308 Views)
01-17-2013 09:59 PM in reply to: micruiz
Click on the path and browse to the correct ACE_IEC_MENU file.
It should be in your user profile\appData\roaming\autodesk\ACAD Electrical\release\enu\Support folder.
Also check that your schematic libraries are also changed from the JIC to the IEC libraries for the oneline circuit /1-/ as well.
Active Member
Message 7 of 15 (302 Views)
01-17-2013 10:37 PM in reply to: lionSG
I did that and clicked ok. However, it reverted to the previous file again.
Valued Contributor
Message 8 of 15 (288 Views)
01-17-2013 11:26 PM in reply to: micruiz
Did you install and select the IEC symbol library when you first installed the ACE?
Goto the Add/Remove program and check again.
Try to delete the lastproj.fil in your roaming support user folder, the file could be corrupted.
Active Member
Message 9 of 15 (276 Views)
01-18-2013 07:53 AM in reply to: lionSG
I tried to uninstall and reinstall it without the jic symbol library, and when I opened  it, I still couldn't change it the Schematics Icon Menu Wizard.
Valued Contributor
Message 10 of 15 (250 Views)
01-20-2013 06:42 PM in reply to: micruiz
I suspected you may have a existing JIC format drawing opened.
Try to open a new drawing or project and see if it worked anot.
Thanks.
You are not logged in.
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
