AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
error: bad argument type: streamp nil
2 REPLIES 2
Dave03
7142 Views, 2 Replies
Hi Guys,
Our IT recently upgraded me to a new laptop.  They loaded it with AutoCAD Mechanical 2007, AutoCAD Electrical 2007, and Inventor 11.  AutoCAD Mechanical seems to work fine, but AutoCAD Electrical produces the error
Command:
; error: bad argument type: streamp nil
Command:  ; error: An error has occurred inside the *error* functionbad
Command:
whenever I select an Electrical function.  All other regular AutoCAD functions work fine while in Electrical.
I do notice that when AutoCAD Electrical first launches that the Electrical Menu Utilities do not load. It displays the error
AutoCAD Electrical menu utilities ; error: bad argument type: streamp nil
Any help would be greatly appreciated.
2 REPLIES 2
in reply to: Dave03
I'm working with AutoCAD Mechanical 2011, recenlty upgraded from XP 64 to Windows 7 and I too am receiving this same error after opening a drawing.
Everything else seems to be wokring fine.
Thank you
KevinLi-Autodesk
Try to check if your current workspace has been set after launching, it should be set to ACADE&2D Drafting & Annotation as default. If not, manually set it.
Second suggestion is to check if acade.cuix file is loaded or not.
Kevin Li
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
Autodesk, Inc.
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
”Boost
