Hey guys,
Basically i want to be able to make small changes to the already existing autocad components without having to create my own for every single component.
I open up block editor, add the required attributes and then overwrite the existing block when saving. I can then add it to my existing drawing and my added attributed appear in the miscleaneous tab just fine, but when I select another drawing, or create a new one in the same project all of my changes to the component seem to dissapear. any idea's?
I have created plently of my own components which save just fine when saving it as a new block, does the software not allow autocads standard components to be overwritten?
thanks
James
Solved by dougmcalexander. Go to Solution.
