Joe, after reading again what you wrote I think I misunderstood what you
wanted to do. I think you would need to create a catalog table for Dinrail
in your catalog lookup. The table should be called DIN. Basically, once you
insert a piece of dinrail, edit it and select catalog lookup. Then make
sure to create the table DIN. From this point, you can add the part
information, making sure the MFG, PART NUMBER, and ASSYCODE exactly match
what will come from the spreadsheet. The BOM will then pair it up when run
and extract any of the data you may have entered for descriptions and the
USER1 and USER2 fields.
Hope this helps,
Pat Murnen
wrote in message news:5160178@discussion.autodesk.com...
Nate,
I tried what you have suggested. I was able to put the fields on the drawing
doing this, but it still does not give the information to me on the panel
BOM. I was kind of thinking that it may be something in the wddinrl.xls
spreadsheet, that is I can add components to this spreadsheet and modify the
blocks, but I need to add user1 and user 2 fields for the BOM to pull the
information. Just like when I add my companies part numbers to the user1 and
user 2 fields for schematic and panel components. I what to preload the
information and then ACE will pull the information from a catalog or the
spreadsheet.
Joe
