hai,
am just a starterof electrical Auto CAD ,so can anyone tell me how to use the dentrail icon .by step by process with example.
Thanks in advance.
Select the DIN rail from the drop-dpwn arrow list. It defaults to Allen-Bradley 199-DR1. You can click the butn labeled "Pick Rail Information" and use your mouse pointer to select a starting point and ending point for the rail. You can adjust (round-up or round-down) the length afterwards in the field below the box. Click OK to finish (see attached image). The Insert/Edit dialog will appear next. The MFG and CAT will already be assigned, using the part number you chose from the drop-down. You could change the assignment if desired. You can type in a Tag designation as well, if you tag your DIN rail.
