Hi
I'm trying to modify source/destination signal cross reference format for same one as on attached picture. There are 3 ATTRIBUTES in same line but equal space between them. Can anyone help?
wodji
If you right click on your project file, then choose Properties. This will bring up the Properties box, then choose the Cross-References Tab. It will allow you to modify the format. %D is for Drawing Number %S for Sheet number, %N for line number and so on. Hope this helps.
