Use the BATTMAN command to synchronize the block. This will synchronize all
the inserted blocks with the correct amount of attributes. An inserted block
(a block reference) won't automatically get attributes that are added to the
block definition after it was inserted.
THL
"Doug McAlexander"
wrote in message
news:5979516@discussion.autodesk.com...
> Make sure you set the attribute to Invisible=No using the Properties
> command.
> wrote in message news:5979456@discussion.autodesk.com...
> i am attempting to create a block and that has to have a visible tag
> (text) next to it. i have made the block but whenever i try to define an
> attribute the attribute is only visible from the block editor, once i get
> out of the block editor the text disappears in paper space and model
> space, i go back into the block editor, and the text reappears.
> I have also tried to just added text to the block . this will not work
> because the text has to be changeable. (because the motor, or conduit
> number changes)
Trond Hasse LieAutoCAD Electrical and
EPLAN expert
Ctrl Alt ElPlease select "Accept Solution" if this post answers your question. 'Likes' won't hurt either.
