I need my PDF's individual!
Can I generate individual pdf's from SSM?
Try using the Publish to DWF instead of plot. You select the drawings, select which tab you want to print and UNSELECT Run Publish in the background. Top left select Publish to: PDF. Under publish options be sure to set the Location to where you want the file to go. For type: select Multi-sheet file then change any other settings you want and hit OK. Select Publish and it should make the PDF.
This method still creates (1) PDF with all the sheets in it.
I need separate PDF's created for each sheet.
Well it worked this time?
It hasn't in the past.
Thanks ronbotkin
For sheet set publishing, set the variable "publishcollate" to <1> for all sheets to be in (1) pdf file.
And set the variable "publishcollate" to <0> for all sheets to be individual files.
Hope this helps someone.
MGEE
