Spare
It sounds like a permissions issue with the location you have placed the
drawings. Try doing just a normal File open from AutoCAD and see what
happens. Also, a single drawing can be tied to two different projects, you
just have to understand that when it changes in one, it changes in all
projects that it is reference, so in most cases, this is not a very good
solution. Generally, you will copy the drawing or project into a new
design.
I hope this helps!!
Jared (Autodesk)
wrote in message news:5164083@discussion.autodesk.com...
You cannot have the same drawing in two different projects. You pretty much
have to just copy all the drawings in the project and make a new project.
