AutoCAD Electrical General
Distinguished Contributor
acade2012
Message 1 of 3 (291 Views)
components NOT SHOWING TEXTVALUES
291 Views, 2 Replies
11-27-2012 11:33 AM
Hello All,
I am having an issue with inserting a component onto my schematic and the ratings not showing up.
In the look-up catalog under the textvalue is the desired ratings i.e.FUSE (RATING1=5.0 A;DESC1=CLASS "CC").
The ratings used to populate but have since stopped.
Is there a setting for this??
Both users here are having the same issue.
As stated above it use to work fine.
Any ideas??
Dennis
acade2012
Message 2 of 3 (265 Views)
Re: components NOT SHOWING TEXTVALUES
11-28-2012 05:04 AM in reply to: acade2012
FYI for anyone else having this issue.
I have found the cause of the issue.
I recently modified the access data base to include the company part number.
I added a column to the data base.
once I went back and removed the column it started to insert the text values again.
The column needs to be added to the end of the data base to work correctly
testsubject
Message 3 of 3 (255 Views)
11-28-2012 07:02 AM in reply to: acade2012
Dennis,
Good catch. In all my years of using ACE I never added a column to the database.
Always learning something new...
Bob Hanrahan
Ace User since 1998
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
