AutoCAD Electrical General
Distinguished Contributor
iomaxx
Message 1 of 5 (121 Views)
child cross reference blanks out
121 Views, 4 Replies
05-09-2013 04:34 PM
I'm having an issue where I have a XREF field on a child device that looks to update when i select the parent, but after clicking OK, the XREF field is blanked out for some reason. If i go back into edit component a second time, the XREF will 'stick' and not be blank when i click OK. The other fields (TAG, LOC, etc) aren't blanked out like this, only the XREF attribute. Any thoughts?
Thanks.
vladop
Message 2 of 5 (107 Views)
Re: child cross reference blanks out
05-10-2013 06:54 AM in reply to: iomaxx
Are TAG, INST or LOC strings too long.
I had similar problems because INST value was too long.
I don't remember exactly, but I think it should be less than 16 characters.
*Expert Elite*
dougmcalexander
Message 3 of 5 (99 Views)
05-10-2013 07:06 AM in reply to: iomaxx
Vladop has offered you some good advice. I would recommend using abbreviations for Installation and Location codes. These come from the DIN and now IEC standard and ate usually kept to 2-3 letters maximum.
If this is an isolated incident I also recommend deleting the project scratch database. Shut down the software, go to the User sub folder where scratch databases are saved, and delete. This builds a fresh new project scratch database and often clears up oddities.
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
iomaxx
Message 4 of 5 (98 Views)
05-10-2013 07:07 AM in reply to: vladop
The TAG is 7 characters, the LOC is 5, and the INST is empty.
*Expert Elite*
dougmcalexander
Message 5 of 5 (96 Views)
05-10-2013 07:10 AM in reply to: iomaxx
Just curious. Does it update okay using the update cross references utility?
Doug McAlexander
You are not logged in.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
