AutoCAD Electrical Forum
catalog data (how to)
1 REPLY 1
142 Views, 1 Reply
Can someone explain to me how you apply the catalogue data for the next item.
insert a "timer" "ON delay coil"
Now I want to make this timer out of two pieces of equipment
1) the actual relay itself (example: AB 100-C09K010)
2) the delay equipment (example AB 100-FPTA180)
3) edit component and change "catalog data"
When I try this I only get timers. When I choose "other" I can refer to my relais (true CR), but when I then want to refer to my 2nd equipment I can not choose any AB (= Allen-Bradley)equipment anymore. What do I do wrong?
1 REPLY 1
dougmcalexander
If you have the coil and delay timer entered into the catalog database separately, it seems to me that you could assign the coil as the main part and use the Multiple Catalog area to enter the delay timer. You might also consider using the Assembly Code feature to automatically associate coil and delay timer.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
”Boost
