Happy2969 and John0070,
Before deciding to re-image the computer, there is one other step you could
take. Doing this however, will cause you to lose most of your
customizations that you have made to the environment since you installed.
Before trying this, make sure AutoCAD Electrical is not running. Another
user, Josdc suggested that you delete the following registry key:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R17.0\ACAD-5007:409
I would suggest that you rename this key. I would then suggest that you
rename the following folder:
C:\Documents and Settings\[USER NAME]\Application Data\Autodesk\AutoCAD
Electrical 2007
Where [USER NAME] is replaced with your user name. Once you have done that,
just restart AutoCAD Electrical. It will copy over the default set of
settings, as if you were a new user. Please note, only follow this
suggestion if you fully understand how to make changes to the registry and
are comfortable doing so.
Mike
wrote in message news:5346554@discussion.autodesk.com...
I had the same problem with Autocad electrical 2007. No toolbars, no menus
and no workspaces are available in the startup screen where u r supposed to
choose a workspace and make it current. besides when i try to change the
current workspace with "Workspace" command, i don't find any workspaces
listed in "My workspace" drop down eventhough there are two workspaces
listed in the customisation window. i tried all the mentioned suggestions
but none worked. So John if u have any news i would appreciate your help.
