Right-click on the project name in the ESW and make it active if not already active. Next right-click on the project name and click add drawings. Select the blank drawing and click add. Open the drawing and click on the Drawing Configuration Tool and you will be prompted to place down the WD_M block. Be sure that the box next to "Force this drawing's configuration settings to match the project settings" is checked.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
