AutoCAD Electrical Forum
adding DIN Rail to project
4 REPLIES 4
1371 Views, 4 Replies
when I try to add dinrail to drawing I get cannot find or cannot open WDWINRL.XLS. How do I fix this
4 REPLIES 4
dougmcalexander
Make sure that the XLS file is in the Catalogs folder.  If you can perform a Catalog Lookup you should be able to insert DIN rail.  The wddinrl.xls file is in the same folder as defaukt_cat.mdb.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
Icemanau
I've attached the 2008 version of wddinrl.xls in case you can't find it. Do a search for default_cat.mdb and place this file in the same directory.
This has a couple of entries that we use here but still have the ones that come with ACADE.
Regards Brad
Brad Coleman, Electrical Draftsman
I added your wddinrl.xls and it is located in the catalog directory with the default cat.mdb but still won't open
PatMurnen_Adsk
You are trying to insert the din rail from the Panel icon menu, right? If it can't find the wddinrl.xls file you will get a message saying it can't be found along with a long list of folders it is looking in. Put the file in one of those folders and it should work.
Pat Murnen
Principal Content Developer
Product Development – AutoCAD Product Line Group
”Boost
