Hi Pmasck,
After you switched to the ACADE profile, change the paths in the support file search path. The first line has in the search paths must be the location where you are acade.rx file is stored. Normally this is C:\Program Files\Autodesk\Acade 2008\Support\AcadE
Close AutoCAD E, and restart it, now it should be fine.
