AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
acade 2009 catalog path issue HELP!!!
1 REPLY 1
185 Views, 1 Reply
In the wd.env file I pointed my default catalog with the following syntax: WD_CAT,I:/acade2009catalogs/practice copy Gavan defaultcat.mdb
I even tried fwd slashes and listing this path as the first item in the support file paths and still I get "no catalog lookup found" in the project settings window even after I close and reactivate the project.what is the DEAL!!!
1 REPLY 1
ok I found that if you name the database anything other than DEFAULT_CAT.MDB THE FILE IS NOT RECOGNIZED WHEN YOU CALL UP THE PROJECT SETTINGS!!!!!!!!!
Once I renamed the db file back to default it worked fine!!!
”Boost
