AutoCAD Electrical General
Member
Scott.Papworth
Message 1 of 4 (1,735 Views)
Zoom Extents not locating All of / Centre of Dwg.
1735 Views, 3 Replies
03-22-2013 04:34 AM
I'm new to this so my apologies if im posting in the wrong place.
I'd like a bit of help on an issue i come across regularly at work.
Here goes...
If i want to Double click the mouse wheel or 'Zoom>Extents' within a drawing, i sometimes get the visual sensation of there being a 'foreign object' hidden somewhere else in the drawing space. Which therefore obscures my view of what shouldve been my drawing 'extented'. From here i go to the opposite side of the view and search for any unwanted objects. In this case, i higlight the area and nothing appears to be there. I literally cannot find anything that would be causing my obstructuction for extenting the whole drawing as normal.
Any ideas as this becomes highly frustrating?
Thanks.
Member
Scott.Papworth
Message 2 of 4 (1,733 Views)
Re: Zoom Extents not locating All of / Centre of Dwg.
03-22-2013 04:37 AM in reply to: Scott.Papworth
Should really mention im using AutoCAD Electrical 2013.
Valued Contributor
metal_pro2
Message 3 of 4 (1,695 Views)
03-22-2013 06:40 AM in reply to: Scott.Papworth
Are any layers turned off? Objects on a layer turned off affect zoom extents.
if not try this to look for some junk in the drawing that is affecting your zoom extents
At the command prompt
Command: ATTDISP
Enter attribute visibility setting [Normal/ON/OFF] <Normal>: on
This will display blocks with invisible attributes like WD_M
Also you can
Try and do an Erase then type All, then R for remove. Put a window around objects you don't want to erase (titleblock). then enter to finish the command.
You can see from the command prompt in the example below there were more objects then in the title block. Don't erase your WD_M block
Command:  ERASE
Select objects: All 160 found 2 were not in current space.
Select objects: R Remove objects: Specify opposite corner: 154 found, 154 removed, 4 total
Remove objects:
Set Your ATTDISP back to normal and zoom extents to see if it works.
Member
Scott.Papworth
Message 4 of 4 (1,688 Views)
03-22-2013 07:24 AM in reply to: metal_pro2
Some things there i wasnt aware of.
Thanks alot !
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
