AutoCAD Electrical Forum
Wish List
3 REPLIES 3
229 Views, 3 Replies
Wish List
1. The option for wire #s & copies not to move
unless the wire they are directly above moves.
2. A cable parent that is not a conductor, but
which contains the info for the conductors in
it, an easier way to handle Profibus cables etc.
3. Either CAT and MFG on the same layer, or a
way to to show and hide on dwg.
4. Main Report Builder - More customization, add buttons
for created reports and report formats, can merge/concatinate fields of choice, ratings/descriptions on reports other than BOM
5. A rating/field dedicated to LOAD.
6. Subassembly catalog items listed/editable from
the Main assembly component. Subassembly items not
unique to assembly - ie I can use the same connector
on many cables without duplicating the connection
catalog entry to give it an unique assembly list name.
3 REPLIES 3
Add to wish list the ability to select with window
to the wire cutter utility, much like erase works.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
1.
BOM
on many cables
assembly list name.
Another nice thing would be to be able to
see a "thumbnail" of all the drawings in a
project and be able to open them from there.
Maybe what you'd like is already there. When you click on view the highlighted drawing in a project opens as a thumbnail and you can then open the drawing frome there. Not sure if that is what you were asking for or not.
”Boost
