Can I connect the wires to the terminals of one component, so that the wire is displayed in the report?
Solved by galashkina. Go to Solution.
Solved by rhesusminus. Go to Solution.
Can you post the DWG?
Then I could have a look...
Something with my symbol is not so. Checked on the other - works.
I'm not sure WHY, but if you draw like this, it works (i.e. You must use multiple wires to connect)
Maybe someone from Autodesk can explain why?
These wires are included in the report? I do not.
If you insert the cable core, they will turn into the report.
Yes:
rhesusminus, thank you! You helped me again.
If the connection is to create not one, but several segments arranged in a single line, the report turns out right.
