I would like to add the Component Tag info to a Schematic WIre to/from report. Can this be done? How?
Not really sure what you are askinng for.
CMP1 and CMP2 are the component tag values.
Could you be more descriptive?
Below is what I would like the report to look like. The tag is the unique identifier of the component.
12/5/2011 10:30:12 AM
Wire From/To report for Drawing 020.dwg
TAG LOC1 PIN1 WIRENO TAG LOC2 PIN2
WG1 R10-A3 P3-18 WD1-A IO1 R10-B17 WD2-A
John,
I am sorry, but I still do not see what your issue is. It seems like you were able to change the report that was generated to reflect the column titles that you want. CMP1 is the unique component TAG value for the component on the left and CMP2 is the unique component TAG value for the component on the right.
Are you using other fields for TAG values??
No Bob I cheated. What your looking at is what I created in word not the what was output from the report.
OK!! Got it!!! It's the CMP1 & CMP2 that I need to add to the report to get the tag info I needed. Much thx!!
That is what was throwing me off. The report you showed was what was available from ACE with a little tweaking...
