Paul,
I think you can just copy one of the existing terminal dwg files to a new
name and then modify the graphics to suit your needs. Make sure that your
new symbol's name keeps the "HT1..." or "VT1...." prefix.
You might take existing symbol HT1001.dwg and copy it to a new name like
HT1_SPLICE.dwg. I think you can keep the existing attributes in place.
See it this works for you.
Nate.
wrote in message news:4946389@discussion.autodesk.com...
Hi Nate,
Thanks for your response. The blanked terminal does what I want as far as
splitting the wire, but I don't like that all the choices look like the real
terminal blocks that I already have in my drawing.
I want this to look different - just two wires spliced together. A simple
DOT would work perfect. Can I modify one of the blanked terminals symbols
so that it looks like a DOT but still splits a wire? Do you happen to know
which attributes are used for the wire splitting functionality? I'm sure I
will have to move those a bit.
Thanks again,
Paul
