Show only
Search instead for
when I have a wire carrying a COM signal that appears in 2 locations.....coming out of different devices..... they both have arrows on the wire. When I place the second arrow, ACE points to both wires. I do NOT want this. I am assuming the only work around is to have different signal manes? EX. COM-1 and COM-2? Any help would be appreciated
What are you using as the S/D code? Try using a different code for each location, such as your COM-1 and COM-2. Note that the wire number COM can be the same for each wire, though ACE will flag it if you run Audit.
