AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Wire numbers on a per wire basis
2 REPLIES 2
blackseabrew
334 Views, 2 Replies
When generating wire numbers, with 'per Wire Basis' selected, I still get just one wire number on a network with multiple terminals.  Would like to get a seperate number for each wired from terminal to terminal.  Any suggestions?  The drawing is attached.
2 REPLIES 2
rhesusminus
in reply to: blackseabrew
Hi.
Not sure if this is what you wanted, but here I've renamed the terminals you've used, using the RENAME command i AutoCAD. THe terminal blocks' name now start with HT1 (Triggers wire number change through termnial) instead of HT0 (Does NOT trigger a wire number change). See attached file.
THL
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
blackseabrew
in reply to: rhesusminus
Отлично!  (That's 'perfect' in Russian)  Much appreciated and thanks so much.
”Boost
