Hello Peter_KSBE
Are you aware of the project-wide command that can fix/unfix wire numbers
across the entire project/drawing(s)?? (it can actually complete several
other tasks as well). You can access this by going to the PROJECTS pulldown
menu and selecting the command "PROJECT-WIDE UTILITIES". On the left of
this dialog you will see the options for setting the state of the wire
numbers. Once you have selected the task you wish to complete and select
OK, you will have the ability to choose to run your selections on the ACTIVE
DRAWING or PROJECT. If you choose project, you can pick and choose the
drawings you wish to run this command on and are not required to select all
of them. Let us know if you have any more questions.
I hope this helps!
Jared
Check out the AutoCAD Electrical blog by Nate Holt at:
http://mfgcommunity.autodesk.com/blog/nate/
wrote in message news:5342143@discussion.autodesk.com...
There is a command to fix wire numbers under the "edit wire number" flyout.
Here you can click one after the other. But is there somewhere a similar
command to put them back to normal again in the same way?
Now i have to edit them one at the time.
