In my limited experience, the Automatic wire numbering places all of the wire numbers in model space. Is this correct by default, and is there a way to switch it to paper space? Or do you all do ladder and wiring diagrams in model space?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
To the best of my knowledge, there are unresolved coding clashes which mean that when working in Paper Space, a number of drawing automation tasks cease to work correctly. The affected functions I've either heard about or come across myself include :
Positional cross-referencing between parent / child symbols, Intelligent inter-sheet notation, and Title Block Update (won’t work consistently - or at all). Also, sheet numbers can get evicted from drawing properties, which means that source / destination arrows may lose their way. Export / Update (to / from spreadsheet) is robbed of some functionality, and additionally - of particular interest to yourself - wire numbering becomes a bit of a lottery.
Doubtless others will have more fulsome explanations, but the answer seems to be to only ever use AE in Model Space.
Hope this helps
Keith H
