Use AEPLCWIRENO on any electrical symbol.
I want to add the wire number suffix data into our electrical symbols, so the wire numbers are more descriptive and easier to generate. A good example would be a motor encoder. I want the wire numbers to look like this . . . . 1000A+, 1000A-, 1000B+, 1000B-, 10005+, and 100COM. If I add the TAGA attribute to our AC drive electrical symbol, then I can use the AEPLCWIRENO command (PLC I/O) to generate the wire numbers. %S%N. Where can I find more information on the attributes (TAGA and etc) that can be used, when generating electrical symbols?
Attributes TAGA01, TAGA02, TAGA03, etc., are used to store the address data for each addressable point on a PLC module. If the option to use the PLC address as a wire number is checked in Drawing Properties, any wires that connect to an addressable point on a PLC will be assigned the PLC address.
