AutoCAD Electrical Forum
Wire gauge/color setup request
1 REPLY 1
Lintt
180 Views, 1 Reply
I would like to perminantly set my wire gauge colors to ALWAYs be on my "gauge" layer. I like to hide this layer for some purposes (to lessen clutter on the drawing)
But whenever I go back to the command, it reverts to misc and sym layers.
1 REPLY 1
in reply to: Lintt
You are correct... it looks like this setting, if you change it, is lost
when you exit AcadE and then resets back to the MISC and SYM layer when you
restart.
There is not a good solution for 2006 and prior to have it come up to some
other value by default. The only thing I think of that you could try is
this: make sure these two Lisp expressions execute when you start AcadE:
(setq GBL_wd_colga_textlay "GAUGE")
(setq GBL_wd_colga_leaderlay "GAUGE")
This should preset the layers to "GAUGE".
wrote in message news:4989923@discussion.autodesk.com...
”Boost
