I've inserted cable markers on my schematic and they show up in my cable from/to reports. However, I'm not able to get the wire color/id to show up. It's probably something dumb but I haven't been able to figure it out. I'm running 2013SP1. Any suggestions?
thanks
Solved by algerj. Go to Solution.
Hi Adam,
In the report go to "Change Report Format".
Use "CBLWC" if your want to pull out the colour assigned on the markers.
I hope this helps,
James Alger
SolidCAD
Thanks James,
That took care of it. I mistakenly thought the WIRECOLOR1 was for this.
thanks again.
