AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Wire Text?
2 REPLIES 2
221 Views, 2 Replies
Wire Text?
Is there a way to add text above a wire and have it follow the wire when scoot is used? ex: (70V RAIL OUT). I was able to add text as a break in the wire but the customer does not want this.
Tim
2 REPLIES 2
possibly add as extra wire number, then edit text to read as desired?
You might try this idea (untested)... the "you type it" in-line wire label symbol is \HT0_LGENERIC.dwg. Open this open in AutoCAD and move the COLOR attribute up. Draw a LINE entity between the insertion points of the two wire connection point attributes X4TERM01 and X1TERM01. It should pop in with the editable text above the wire and be scootable. See if this can meet your needs. "Nitro" wrote in message news:20320287.1084882355438.JavaMail.jive@jiveforum1.autodesk.com... > Is there a way to add text above a wire and have it follow the wire when scoot is used? ex: (70V RAIL OUT). I was able to add text as a break in the wire but the customer does not want this. > Tim
”Boost
