AutoCAD Electrical General
Valued Contributor
Message 1 of 2 (181 Views)
Wire Number Text Size
181 Views, 1 Replies
02-07-2013 05:09 AM
Can someone please advise how to set the wire number text size and wire gap size. I am using the auto wire insert and when wires cross I want a gap to be inserted, so the gap needs to open up when the text size is increased.
Distinguished Contributor
s.wile
Message 2 of 2 (167 Views)
Re: Wire Number Text Size
02-07-2013 06:48 PM in reply to: STEVENAR
Are you referring to the text in-line with the wire as in
-----123-----
The gap settings are in the drawing properties \ WireNumber Tab \ New Wire Placement \ In-Line \ Gap Setup... Button.
The wire number height should be done at the block level. The block names for in-line wire number are: WD_WNH1 and WD_WNV1
If your changing them, you should change the rest as well.
Above wire: WD_WNH and WD_WNV
Below wire: WD_WNH2 and WD_WNV2
Or do you mean when another wire happens to run through another wires wire number?
Stan Wile
http://myacade.blogspot.com/
IMAGINiT Technologies
You are not logged in.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
