AutoCAD Electrical Forum
435 Views, 1 Reply
Wire List
I had some schematic made using AUTOCAD, my goal is to export the wire list including the information of the wire name, from/to, wire guage and the length. I believe AUTOCAD Electrical should be the right software for this kind of reporting. Could anyone give me some guideline? Thanks
Tags (1)
1 REPLY 1
lionSG
I believe you need to convert your blocks into electrical components and lines into wires first.
you can make use of the Conversion Tools tab to do that.
Then you can do a to/From report from the Report tab.
If you need more info, you can look into the Tutorial in the help files.
Hope this helps.
”Boost
